eveares
Jan 14, 2018Aspirant
Questions about the ReadyNAS 424
I am new here and am concidering getting a Netgear ReadyNAS 424. I currentley have a Asustor AS-5004T and want to upgrade it to something better what must incldude native windows based Fil...
eveares
Thanks for your reply; in reponse:
1) Why would you say to consider the RN426, RN428 and the RN520 series if I want the option to upgrade the RAM and then say that you don't support upgrading the RAM in any of the desktop units. Are the units/series mentioned above not classed as desktop units? Also, how much RAM does a NAS box need when one person is using it like a local drive plus for some general backup stuff?
2) That's all and well, I don't know that much about DFS as have yet to have a DFS compatible NAS box. Is DFS replication possible with ReadyNAS OS?
5) Can one use a conventional alphanumeric password to encrypt a volume/share rather than a USB Key?
Regards: Elliott.
mdgm-ntgr
Jan 14, 2018NETGEAR Employee Retired
1) You can upgrade the memory in the RN426, RN428 and RN520 series even though it's not supported. For most users upgrading the RAM should only have a marginal benefit. All the models you and I mentioned are desktop units. We do have some rackmount models that we sell memory modules for.
2) DFS Replication is not possible. There are a number of ways you can backup your data though.
5) No. The encryption key is stored in a file on a USB key.
