Hewlas's avatar
Hewlas
Follower
Dec 04, 2017
R104 drive 4 warning
I am getting a message that details a possible failure of disk 4 on my readynas system.  I have 4 drives and they are all 2 tb.  I can physically change the drive but how do I transfer the data that ...
  • yxue's avatar
    Dec 04, 2017
    What's your raid? If you are in X-raid mode, NAS creates a raid5 volume with all the four disks, you can hot-remove the disk4 out , then hot-insert a new disk, NAS will sync automaticlly. Thank you!
ProSupport for Business
