davidr1
Feb 10, 2014Luminary
Radiator-x86--V4.4.26 - says wrong architecture
Ultra 2
Pro 2
I downloded RAIDiator-x86-V4.2.26.zip to do a local upgrade on both the above.
Verifying the image reorts "Update file is not valid for this architecture".
I have downloaded twice and both NAS' say the same.
Any suggestions please?
David
Pro 2
David
- StephenBGuru - Experienced UserUnzip the download and upload the binary inside.
- davidr1LuminaryThanks StephenB.
I've done this often enough I should have remembered -
David - StephenBGuru - Experienced UserPersonally I think Frontview should check for that - it knows the file extension, so it would not be difficult.
- davidr1LuminaryI didn't like to say - I 100% agree with you. One downlads for 'local' - one chooses that file ...
- chirpaLuminaryThe added that smarts in R6, to know if its zip and extract it. But R4 does not have this.
