Cyrmel
Nov 27, 2020Aspirant
Raidar 6.5.0 not finding NAS RND2000V2
Hello, I can see my ReadyNas DU0 RND2000V2 with Raidar 4.1.3. On the other hand, when I run Raidar 6.5.0 it cannot find it. I disabled the firewall without success and I can ping my NAS, ...
Nov 27, 2020Guru - Experienced User
RAIDar 6.5 should be able to discover your NAS - so that is a mystery. Did you also disable internet security software on the PC (Kaspersky or Avast)?
As far as compatibility goes, one thing you can't do with 6.5 is convert your NAS to run FlexRAID. That requires the older version.
Cyrmel
I disabled Avast and Zone Alarm. I also use Raidar 6.1.0 but I can't found NAS. Raidar 4.1.3 find it. My Readynas use RAIDiator 4.1.7, I don't now if there is some incompatiblity with Raidar 6.X version.
I will attemp to use raidar 6.5.0 in another PC
- StephenBNov 27, 2020Guru - Experienced User
RAIDar 6.5 finds my legacy NAS, and the discovery protocol hasn't changed. It would be good to try this on a different PC next.
- SandsharkNov 27, 2020Sensei
Could be a JAVA issue.
- CyrmelDec 01, 2020Aspirant
I try with another PC and also update Java, but no change. I also try to connect NAS directly in the switch (Before that, it was connected thought box provider) with my PC and no change. The NAS was only visible with raidar 4.1.3
