Cyrmel
Nov 27, 2020Aspirant
Raidar 6.5.0 not finding NAS RND2000V2
Hello, I can see my ReadyNas DU0 RND2000V2 with Raidar 4.1.3. On the other hand, when I run Raidar 6.5.0 it cannot find it. I disabled the firewall without success and I can ping my NAS, ...
Cyrmel
I disabled Avast and Zone Alarm. I also use Raidar 6.1.0 but I can't found NAS. Raidar 4.1.3 find it. My Readynas use RAIDiator 4.1.7, I don't now if there is some incompatiblity with Raidar 6.X version.
I will attemp to use raidar 6.5.0 in another PC
Nov 27, 2020Guru - Experienced User
RAIDar 6.5 finds my legacy NAS, and the discovery protocol hasn't changed. It would be good to try this on a different PC next.
- SandsharkNov 27, 2020Sensei
Could be a JAVA issue.
- CyrmelDec 01, 2020Aspirant
I try with another PC and also update Java, but no change. I also try to connect NAS directly in the switch (Before that, it was connected thought box provider) with my PC and no change. The NAS was only visible with raidar 4.1.3
