jonjon79
Oct 23, 2020Aspirant
RAIDar 6.5.0 not finding ReadyNAS Pro 6
hello. I just treated myself to a new Win 10 laptop. I still have my old Win 7 that I did update to Win 10. trying to get RAIDar setup on my new laptop. downloaded RAIDar 6.5.0 but it does not fin...
- Nov 04, 2020
You can reach the web ui (frontview) of the NAS from the Win10 web browser?
Assuming that is the case, then the next step is to go into "turn windows features on or off" on the PC, and make sure the SMB 1.0 client is enabled. 4.2.x firmware only supports SMB 1, so you will need to enable it (and ignore any security warning).
After you enable SMB 1, try to access the NAS using file explorer. Enter \\nas-ip-address in the address bar (using the real IP address of course). Make sure you use the correct slash.
jonjon79
Nov 04, 2020Aspirant
hello again. tried the Surface adapter on my Dell - worked great! obtained IP address easily, right away, and on same /24 network with the NAS. laptop = 192.168.1.110, NAS, that I can still browse in Win Exploder from the new Dell = 192.168.1.84. so the Ethernet adapter helped, but problem with RAIDar still unresolved.
what do we do next? and thanks in advance.
-John
Nov 04, 2020Guru - Experienced User
