Pete10p
Sep 12, 2020Aspirant
Raidar has stopped seeing ReadyNas
I have had Raidar 6.5 running on my Winows 10 PC but suddenly its stopped finding my ReadyNas units. The units are there and working fine and accessable from my browser but nothing now shows on Raida...
JohnCM_S
Sep 12, 2020NETGEAR Employee Retired
Hi Pete10p,
Do you have any security software installed on the Win10 PC? You can try disabling that and see if RAIDar can detect the NAS.
You can also try it on a different PC and see if you will still have the same issue.
- Pete10pSep 13, 2020Aspirant
Thanks for the response.
I tried that with no change.
From my browser I rebooted both ReadyNas's and Raidar can see them. I'm not sure why that fixed the problem but so far all is OK.
