iposner
Jul 02, 2012Aspirant
RAIDIATOR 4.1.9 Upgrade - Access Denied to some CIFS Shares!
If you have run into this issue please upgrade to 4.1.10: http://www.readynas.com/RAIDiator_4_1_10_Notes You can then use the Advanced Options tab (go to Shares > Share Listing > Sharename then click...
pugilares
Here you can download 4.1.8
http://www.downloads.netgear.com/files/ ... ator-4.1.8
Personally I didn't try to downgrade yet, even if I have similar problems after upgrading to 4.1.9
EDIT:
So I just tried to downgrade from 4.1.9 to 4.1.8 locally, but I do not have success with this. I get something like "local image sending failed" error message.
EDIT2: Problem with downgrade solved. It was probably timeout of firmware image upload to the ReadyNAS due to stiff set ethernet connection to 100 Mbit full duplex. Now changed to auto.
EDIT:
