iposner
Jul 02, 2012Aspirant
RAIDIATOR 4.1.9 Upgrade - Access Denied to some CIFS Shares!
If you have run into this issue please upgrade to 4.1.10: http://www.readynas.com/RAIDiator_4_1_10_Notes You can then use the Advanced Options tab (go to Shares > Share Listing > Sharename then click...
iposner
Jul 03, 2012Aspirant
melvsee wrote: I have the same problem. Setting "share access everyone" to "read/write" as a workaround.
Doesn't work for me. Setting default read/write and allow guest still produces "Access is denied".
What I need to know from someone at ReadyNas is whether you can downgrade 4.1.9 to 4.1.8 with no ill-effects.
