iposner
Jul 02, 2012Aspirant
RAIDIATOR 4.1.9 Upgrade - Access Denied to some CIFS Shares!
If you have run into this issue please upgrade to 4.1.10: http://www.readynas.com/RAIDiator_4_1_10_Notes You can then use the Advanced Options tab (go to Shares > Share Listing > Sharename then click...
PapaBear1
Jul 04, 2012Apprentice
Does it actually say nobody/nogroup or are the fields blank?
I no longer have an NV+ available to me, but here is my setup on my NVX. Note that the setting up the groups restricts the access to only those groups. The restriction is set by the check mark. Also check the default access field to ensure it has not reverted to "disabled".
Here is the page on my NVX:
