iposner
Jul 02, 2012Aspirant
RAIDIATOR 4.1.9 Upgrade - Access Denied to some CIFS Shares!
If you have run into this issue please upgrade to 4.1.10: http://www.readynas.com/RAIDiator_4_1_10_Notes You can then use the Advanced Options tab (go to Shares > Share Listing > Sharename then click...
pugilares
Jul 04, 2012Aspirant
Papa Bear - what you have is not SPARC, is it?
If you don't have SPARC powered ReadyNAS, then this problem with firmware No 4.1.9 should not be yours, because this firmware doesn't apply to your box.
