iposner
Jul 02, 2012Aspirant
RAIDIATOR 4.1.9 Upgrade - Access Denied to some CIFS Shares!
If you have run into this issue please upgrade to 4.1.10: http://www.readynas.com/RAIDiator_4_1_10_Notes You can then use the Advanced Options tab (go to Shares > Share Listing > Sharename then click...
PapaBear1
Jul 04, 2012Apprentice
1. No, I no longer have an active NV+ (it is at a friends home).
2. That NV+ is still running 4.1.8
3. Here is the advanced options tab on my NVX. As you can see it is set to nogroup (which is the default, even on x-86 units).
4. Since I no longer have access to an NV+ to experiment with, I was trying to find out what all the setting were. After all Frontview is fairly similar across the platforms. Perhaps if you could take some screen shots and post them, it would be helpful in diagnosing the situation.
