kc7gr
Oct 25, 2015Aspirant
RAIDiator 6.4.0 on older hardware? (Active Directory feature)
Good day, I have a ReadyNAS NV+ v2, currently running RAIDiator 5.3.11 with four WD Enterprise 2TB drives. It works quite well, but I've noticed the Active Directory support in this version of RAIDiator seems to be lacking (despite the presence of options to enable it -- what's with that?) Questions: Is this a device which can run under the current RAIDiator version (6.4.0) which, as I understand, fully supports Active Directory, or am I looking at replacing the chassis and moving the disks? If it is a case of replacing the chassis: Will the replacement chassis recognize the disks if I just plug 'em all in, or am I looking at a complete reformat/reinstall? Thanks much.
- mdgm-ntgrNETGEAR Employee Retired
OS6 cannot be run on your NAS.
The new NAS would have a different OS and different filesystem so simply moving the disks across is not an option.
You could either:1. Get new disks for the new NAS and use backup jobs to copy the data across. See e.g. http://kb.netgear.com/app/answers/detail/a_id/29733/~/how-do-i-back-up-data-from-a-raidiator-5-system-to-a-readynas-os-6-system%3F
2. Backup your data, verify backup is good, move your disks across, do a factory default (wipes all data, settings, everything) then restore your data from backup.
- kc7grAspirantI have, since I posted, been successful in enabling Active Directory on 5.3.11. Problem solved! Thanks!!
