ukbobrecover01
Sep 03, 2026Aspirant
Ran Into Problems A Using My RNDuoV2
Dear Forum Members First, had to use a new registration and email to actually make this post, for some reason I could not use my old info to gain access to this forum. Anyway, my problem is t...
ukbobrecover01
Oct 08, 2026Aspirant
Hi Guys
Can't find "View Full Discussion" and the Show more's seem to have ceased to exist.
UK Bob
- schumakuOct 08, 2026Guru - Experienced User
Everything is still around dear Bob
- StephenBOct 09, 2026Guru - Experienced User
Try refreshing the browser, and see if "show more" Then shows up at the bottom of the window.
Is there something specific you are looking for?
If this is a post from a specific user (including yourself), then you can go into that user's profile and get a list of their posts. Then right-click on any that are on this discussion thread, and open in a new window, so you can see it.
Here's a PDF of the full discussion thread.
