Kalle13
Oct 13, 2019Tutor
- can' t backup remotely through ssh and rsync
Hello, I would like to backup some files from a Debian Computer via ssh and rsync. My firmware version is 6.10.1. When I am configuring my remote backup I choose on the left side "remote" and on...
Oct 13, 2019Guru - Experienced User
Kalle13 wrote:
> ??? It needs to be configured as a server on the debian machine in order for this to work.Sure? Here somebody says that if you have a correct verified ssh connection you only need rsync to be installed. Nothing more.
My ssh connection via keys works fine.
I'm not seeing that in your link, though maybe I am missing it.
rsync is a client-server protocol, and the NAS backup jobs are rsync clients. The remote system needs to be set up as an rsync server.
If the remote system were another ReadyNAS, that would be done by enabling rsync as a protocol for the share.
Kalle13
Oct 14, 2019Tutor
Under the heading "How To Use Rsync to Sync with a Remote System". The author discribes two commands with whom you can push or pull the data via ssh to or from the remote system. There is no explanation that you must configure rsync as a server. I am also read this on other websites.
I only read that you have to configure rsync as a daemon if you want to run it like that (what I think you think is the server mode). There a only these two modes: the pull/push via ssh and run it as a daemon. Or may be I am understanding it all wrong.
