Astra03
Oct 05, 2025Apprentice
AntiVirus No Longer Updating
Since 30th September, I have been getting an email from my RN214 advising me that the "Antivirus scanner definition file update failed due to download failure. Check your Internet connection." I ...
Astra03
Oct 26, 2025Apprentice
"systemctl stop --now clamav-freshclam.timer"
What does that command do?
Does it keep clamav running, but stop the daily check for virus definition files updates?
If isn't running ClamAV with out of date definition files really no better than turning off Antivirus on the ReadyNAS because of the extra load on the CPU etc of actually running ClamAV?
Or, am I missing something?
HansRL
Correct : it does keep clamav running, but stop the daily check for virus definition files updates
