Royalblue
Mar 13, 2024Tutor
Can I read a readynas drive on my PC?
Hi, I have a readynas 104 with 4 x 1tb drives inside. I have been having problems with booting the readynas after getting a no ip address error which I couldn't resolve. Is there any way ...
Sandshark
Mar 14, 2024Sensei
I agree with StephenB that the Ethernet hardware is likely working. But since you can't boot, it is possible the issue is with the OS. Try removing all the drives (labeling them if you pull them all the way out so you can put them back in the same order) and see if it then gets an IP address. If it does, the problem is with the OS on the NAS.
Royalblue
Mar 14, 2024Tutor
Hi All
Just trying a reboot and it went quickly to 42% but has stalled there for the last 45 mins. Should I wait longer or try rebooting again?
Many thanks.
