Royalblue
Mar 13, 2024Tutor
Can I read a readynas drive on my PC?
Hi, I have a readynas 104 with 4 x 1tb drives inside. I have been having problems with booting the readynas after getting a no ip address error which I couldn't resolve. Is there any way ...
Royalblue
Mar 18, 2024Tutor
Thank you I'll try that, coincidentally I just found an old empty drive in a drawer so that will work perfectly to try and create a valid volume.
Royalblue
Mar 18, 2024Tutor
Using a clean drive worked, I was able to create a new volume and it booted fine.
I tried to access the boot menu with the reset button held in but again I only got the Normal option?
- StephenBMar 18, 2024Guru - Experienced User
So you have two sets of issues. One is the failure of the reset button, the other is that the volume won't mount.
Earlier (post 16) I posted the ATA and disk spin-up issues that are in your logs. In post 17, you replied saying that when you tested the disks they passed. And the single disk appears to be working ok.
That suggests that the disk issues might be due to inadequate power. That could be an issue in the chassis, or it could just be a failing power adapter. So that could be something to explore.
However, I think the main issue now is to try to get the files off the existing disks. Since we can't get the NAS into tech support mode, your options are limited. Options include
- Purchase ReclaiMe and enough enclosure(s) to allow you to connect all the disks to a Windows PC
- Contract with a data recovery service, and have them offload the files for you.
- Try a USB recovery with the new disk in place, in hopes that it will fix the reset button problem. If that works, then try tech support mode.
- Purchase a replacement ReadyNAS (used), so you can boot up in tech support mode
Options 3 and 4 can be risky, especially for folks with no experience with the linux command line interface.
- SandsharkMar 18, 2024Sensei
There is another possible recovery method. I just posted this update: Mounting-ReadyNAS-drives-in-a-virtual-NAS-for-data-access-and=recovery
Given the ATA errors, I recommend going the drive image route.
The volume is almost certainly out of sync, so this would also require use of ssh.
- RoyalblueMar 19, 2024Tutor
Thank you.
I'll try a new power adaptor first that's pan easy option to start with. 🙂
- SandsharkMar 19, 2024Sensei
StephenB wrote:The volume is almost certainly out of sync, so this would also require use of ssh.
Actually, if you use a VBox VM, it doesn't. You still need to use the Linux command line, but VBox opens up a console window that, with the OS6 version, can be used for that. So if SSH has not been enabled and cannot be, it's still a potential part of a solution.
I've also provided a method of getting into Tech Support mode without the use of the (non-existent on a VM) reset button for units that won't fully boot but where the real NAS reset button menu is non-functional.
- StephenBMar 19, 2024Guru - Experienced User
Sandshark wrote:
... You still need to use the Linux command line,
FWIW, when I talked about ssh in this thread, I was really focused on the linux command line.
On related subject, have you ever installed WSL (Windows Subsystem for Linux)? It looks like that should also be an alternative to using a generic linux VM on the PC. It's on my "to do" list to explore, but I haven't gotten to it yet.
StephenB wrote:On related subject, have you ever installed WSL (Windows Subsystem for Linux)? It looks like that should also be an alternative to using a generic linux VM on the PC. It's on my "to do" list to explore, but I haven't gotten to it yet.
Not since a long time ago when it wasn't capable of mounting the drives. The server I bought to run such experiments on (with 4 easy to load drive bays) quit on me and I have never taken the time to find out why since it's also not Windows 11 capable. I think I just screwed something up with my set-up that allowed me to dual boot to Windows or Linux or even run the same Linux instance as a VBox VM under Windows.
I've used VirtualBox for so long for Linux, older Windows versions, and even MS-DOS that checking out WSL is not a priority for me.
- RoyalblueMar 21, 2024Tutor
Hi Stephen, Sandshark,
I tried a new power adapter but that didn't make any difference.
Stephen in Option 3 post 24 you suggested
Or should I try the method highlighted by Sandshark and mount in a virtual NAS?
Many thanks.
- StephenBMar 21, 2024Guru - Experienced User
If you can create images of the drives on your PC, then Sandshark's method would be the safest path - because you would be leaving the drives themselves intact. So even if you made a mistake, you wouldn't be risking your data.
After the data is offloaded, we can shift back to the reset issue.
FWIW, I was thinking that might resolve the ATA errors. But I did not expect the volume to mount, as the RAID is almost certainly out of sync. If you send me a fresh set of logs, I can see if the ATA errors are still happening with the new adapter.
- RoyalblueMar 24, 2024Tutor
Hi,
<<<<<FWIW, I was thinking that might resolve the ATA errors. But I did not expect the volume to mount, as the RAID is almost certainly out of sync. If you send me a fresh set of logs, I can see if the ATA errors are still happening with the new adapter>>>>
Just tried to get a fresh set of logs but RAIDar didn't find the NAS for some reason. I may give that a go again later, although I did get a alert from my Gmail which said:
'Detected increasing ATA error count: [52] on disk 2 (Internal) [TOSHIBA DT01ACA100, 54NW90MNS] 14 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.'
So maybe the new adaptor didn't help?
