Royalblue
Mar 13, 2024Tutor
Can I read a readynas drive on my PC?
Hi, I have a readynas 104 with 4 x 1tb drives inside. I have been having problems with booting the readynas after getting a no ip address error which I couldn't resolve. Is there any way ...
Mar 19, 2024Guru - Experienced User
Sandshark wrote:
StephenB wrote:
The volume is almost certainly out of sync, so this would also require use of ssh.
... You still need to use the Linux command line,
FWIW, when I talked about ssh in this thread, I was really focused on the linux command line.
On related subject, have you ever installed WSL (Windows Subsystem for Linux)? It looks like that should also be an alternative to using a generic linux VM on the PC. It's on my "to do" list to explore, but I haven't gotten to it yet.
Royalblue
Mar 21, 2024Tutor
Hi Stephen, Sandshark,
I tried a new power adapter but that didn't make any difference.
Stephen in Option 3 post 24 you suggested
Try a USB recovery with the new disk in place, in hopes that it will fix the reset button problem. If that works, then try tech support mode.
Or should I try the method highlighted by Sandshark and mount in a virtual NAS?
Many thanks.
