XrayDoc88
Dec 18, 2017Guide
Folder Missing In ReadyCloud?
I have a folder that I copied to my NAS music folder named ".38 Special". If I browse to that music folder on Windows 10 using "network" I can see the folder (although it is grayed), open it and pla...
- Dec 19, 2017
Yes the dot "." makes the folder a hidden folder. If you can see the folder from your Windows computer, try renaming it without the dot and you should then see it.
dschwartzer
Dec 19, 2017Luminary
