Anton_
Dec 04, 2022Tutor
ReadyNAS 4 Ultra OS 6.10.8, any fix for the fan control?
Running ReadyNAS os 6.10.8 and also replaced the loud fan. The fancontrol worked with the defaul OS. After upgrading to OS6 the fan control stopped working. Nothing happens when chosing silent, bal...
Anton_
Dec 05, 2022Tutor
Is it possible to try and control the fan manually with a command?
Or are fancontrol and lm-sensors or such needed to be installed?
Ive seen that readynasd reported my NAS as ReadyNAS
08/23/2011 ReadyNAS-NVX-V2 V1.10
mdgm
Dec 06, 2022Virtuoso
Anton_ wrote:Ive seen that readynasd reported my NAS as ReadyNAS
That is the latest BIOS for the Ultra 4.
- Anton_Jan 02, 2023Tutor
The new fan spins down within half a second and then turns full blast on NAS booting.
So i guess the system does something with the fan.
I just cant figure out how to control the fan since Silent, Cool and Balanced does not work.
PWM_MIN and all those seems correct.
Maybe i need to post in another sub topic?
ReadyNAS users or such..
