Jophus
Feb 07, 2024Luminary
Readynas 6.10.9 How to manually update IO::Socket:SSL for Logitech Media Server (or other purposes)
So Netgear have dropped all support for Readynas, leaving us on a poor version of Debian 8 Jessie, which is no longer supported. As of 6.10.10 app install functionality has been removed. I use m...
JohnF1
Dec 08, 2024Aspirant
Jophusmany thanks for this post. I've got zero Linux knowledge and it's been very helpful for me in updating the SSL on my RN212.
Appreciate a pointer here, if you can help. When I get to the perl Makefile.PL command, the following error is returned
Can't open perl script "Makefile.PL": No such file or directory
Jophus
Dec 09, 2024Luminary
I am not a linux guru either. I just went through my steps and can see the Makefile.PL
But it looks like a missed a step:
Step 4.5 - change to the newly created directory IO-Socket-SSL-2.083.
cd IO-Socket-SSL-2.083
Then try step 5.
- JophusDec 09, 2024Luminary
As an aside I have relegated my ReadyNAS to be just a straight NAS. It was becoming too difficult to maintain LMS (now Lyrion) and the CPU on the 316 didn't like transcoding x265 videos.
I bought a 5th gen NUC with 120GB SSG and 8GB RAM for AUD$99. It runs Windows 11 (unsupported but works fine with 24H2). I know Windows and it runs Plex and LMS, with it picking up my music files on the NAS via Windows networking.
Aside, Windows 11 24H2 no longer allows anonymous/no password network access. I have stayed on OS 6.10.9, installed SMB Plus and changed the security setting to ensure access is only granted to network connections which can supply user/pass.
Good luck with trying to maintain Debian 8 ReadyNAS.
- JohnF1Dec 19, 2024Aspirant
Step 4.5 did the trick, many thanks again. It prompted a "Should I do external tests?" question, played safe answered "N" and it worked out ok. Sockets updated and radio streaming again.
