Retired_Member
Jul 27, 2020Readynas duo V2 unable to access admin page
Hi All Noticed that I am unable to login to the admin page using RaidR or through the IP address. I used to get a message as it didnt have a secure certiticate but now I can't even bypass that. ...
Sandshark
Aug 02, 2020Sensei
This is great, thanks for it WhoCares_ . I suggest that you add in the ReadMe that it's for OS5.x on DuoV2 and NV+V2.
Any chance users of OS4.1.x or 4.2.x will also be the recipients of your generosity?
WhoCares_
Aug 02, 2020Mentor
Since the note about OS5 is in the upper level Readme already I didn’t think it necessary to add it to the other one as well but will do when I’m back at a device with more pleasant input methods than a glass screen 😂
As for 4.1 and 4.2: I might be able to provide updates for those as well but in both cases I’d have to revive the respective dev environments which especially for 4.1 might be a problem. Also there’s a chance that because of their base os being older it might not be possible to build the SSL library required for TLDv1.2. We‘ll see.
