hby
Sep 17, 2015Aspirant
Readynas nv+ hangs
My ReadyNAS NV+ have suddenly started to hang/freeze. When I power on the unit works for a while but suddenly it hangs. The power button is blue and all disk LEDs are green but when i press the powe...
JennC
Sep 18, 2015NETGEAR Employee Retired
Hi hby,
Welcome to the community!
In addition to Stephen's questions, does the RAIDar see the NAS?
Since you have checked the disks with diagnostic tools, please make sure you insert them back to thier respective bays.
If RAIDar does not see the NAS, check the cable between the NAS and the switch/router where it is connected, make sure both ends are properly plugged in.
hby
Sep 19, 2015Aspirant
Hello.
Yes RAIDar see the Nas.
It is like this.
All is working normal for a while (a couple of hours) and then it hangs again.
Then you have to switch off power on the back and on again.
When you switch on the nas unit it detects the powerbreak and starts to syncronize the disks, that goes well.
It also asks that you should check filesystem by rebboting it, that goes well too.
So after that two actions I open the logs in the Nas to see if anything is wrong but everything is reported okey.
Then suddenly after some hours it has stopped working and is hanged.
Regards
Håkan B
