hby
Sep 17, 2015Aspirant
Readynas nv+ hangs
My ReadyNAS NV+ have suddenly started to hang/freeze. When I power on the unit works for a while but suddenly it hangs. The power button is blue and all disk LEDs are green but when i press the powe...
DaneA
Sep 21, 2015NETGEAR Employee Retired
Hi hby,
I am glad that you bought a new NAS which is an RN102 as it shows into your profile.
Just curious if you were able to transfer you data and access it just fine using your new RN102. Feel free to contact NETGEAR Support at anytime if you need assistance.
DaneA
NETGEAR Community Team
hby
Sep 22, 2015Aspirant
Hi Dane.
I am tranfering my data right now. My old Nas has stopped a couple of times but a restart and a new copy command has completed the copy.
Hakan
- StephenBSep 22, 2015Guru - Experienced User
After everything is moved, perhaps try a factory default on the NV+. If it becomes stable again, you can use it to backup the RN102.
- JennCSep 22, 2015NETGEAR Employee Retired
Hello hby,
Stephen is correct, try factory resetting after getting full backup of the data. Disks should be inserted during the factory reset. This will allow you to reinstall the NAS, like starting from scratch.
In case it fails the reinstall, you may need to check the disks with diagnostic tools.
