arefem
Oct 17, 2022Star
ReadyNAS NV+ stall during File System check at 19%
My ReadyNAS NV+ is stalling during the File System check at 19%. It is visible in RAIDar, and all four disks register as healthy, until the 19% point is reached, at which point RAIDar cannot find t...
arefem
Mar 17, 2023Star
Thank you for all the advice so far. I have made a clean start with new disks in the NAS, and have uploaded from my last saved backup, and am now in the process of uploading the missing music from CDs. I did have a copy of the latest iTunes database, so I have been able to just upload the files, while all the original information like playcount is preserved. Access from the Mac is working well after activating AFP. I have a version of Firefox 94.0.2 running. It was possible to install this in parallel with the latest version, and I just need to remember to dismiss the offer to update to the latest version.
The latest problem I have encountered is in setting up a new backup job. I have registered a USB disk as a share. I used to put the backup in a folder in the USB drive called Backup, however, if I try to navigate to this using Browse, nothing is shown in the Select Folder window, and the browser window just sits frozen. I have tried this also on a PC, and get the same behaviour. Am I doing something wrong here?
SamirD
Mar 17, 2023Prodigy
If the usb drive is also having issues on the PC, then it's the drive. But if not, I would try using the portable version of firefox 52 as I do remember some weird windows like that if the browser version was 'wrong'.
