BMac2021
Sep 26, 2023Tutor
ReadyNAS RNDP6000-Parts? Wont power on.
Good morning group. I wrote a while back about my display not working on the front door of my ReadyNASRNDP6000. I now have a bigger issue...The unit wont turn on at all. Does anyone have the tech man...
- Sep 26, 2023
New PSU ordered..
https://www.amazon.ca/gp/product/B01MEDG1PM/ref=sw_img_1?smid=AEHA1AAWZIC3L&th=1
And cable extension....
thanks for the help...
Sandshark
Sep 27, 2023Sensei
That Apevia looks like a good choice. Has 3 4-pin Molex connectors (that they label "PATA") and higher currents for all voltages than the original. Most especially the 2.5A of +5VSB should help keep that from being the most vulnerable.
BMac2021
Oct 07, 2023Tutor
Sandshark I know we have discussed the issue of the LED on the front door not working. I took the cable off and checked it for continuity and it is fine. Any idea as to how to check the LED board?
- SandsharkOct 07, 2023Sensei
Unfortunately, no. I've not run across a NAS with a display issue except for a pinched cable and one that had become partially dislodged. With no schematic, It's not going to be an easy task.
- BMac2021Oct 07, 2023Tutor
I ruled out the cable. So it is ether the LED board or the MB. I even tried looking up the MB on line but that was no help. I guess I will live with it as is...At least it is running solidly now that the PS changed.
