Steentje
Mar 18, 2019Follower
RN102: System volume root's usage is 85%
Hi,
Today, my ReadyNAS 102 alerted me with this message: "System volume root's usage is 85%. This condition should not occur under normal conditions. Contact technical support." At the same tim...
- Mar 18, 2019
Hi,
I had exactly the same problem. For the solution, which worked on my NAS, please refer to: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-84-This-condition-should-not-occur/m-p/1722230#M178435
asimb
Mar 18, 2019Star
Hi,
