YojiOne
Jul 31, 2025Aspirant
RN102 turns on by itself
Hi all, first post so go easy on me please :) Had the RN102 for over 10 years, on latest firmware (16.10.10) Since it now EOL and not being supported, I have retired it and it is mothballed sinc...
YojiOne
Sep 01, 2025Aspirant
Quick Update... exactly 1 month after it shut down (to the hour/min) it turned itself back on again.
So wondering if it comes on to check for updates or something
So went to settings, there were only two options set re updates..
one was for update notifications... and one for hotfix updates..
So I turned both off... saved.. and have now shut down again..
Lets see if it turns on again in a months time now.
Sandshark
Sep 01, 2025Sensei - Experienced User
So now that you know its schedule, you can schedule a turn-off event a short time later.
