sebastianci
May 03, 2020Aspirant
RN104 not recognizing Seagate Exos 7E8 8TB
Hi My setup: RN104 bay 1 4TB WDC WD40 EFRX- 68WTONO bay 2 6TB ST6000NE0023-2EX110 bay 3 4TB WDC WD40 EFRX- 68WTONO bay 4 6TB ST6000NE0023-2EX110 X-RAID, RAID 5, Firmware 6.10.3 I have tried to...
- Jun 05, 2020
sebastianci wrote:
What is the conclusion, is EXOS 7E8 8TB are just bad ? From your experience do you see more issues with these than any other disks?
Thinking if it is worth buying another one? If true what you recommend for 8TB?
I haven't seen many posts here on the EXOS. Generally people seem happy with Seagate NAS-purposed (IronWolf) and enterprise class drives. DM drives aren't good choices (older ones had high failure rates in RAID, and some newer ones are SMR).
Generally I've gone with Western Digital, and I have sometimes received drives that were dead-on-arrival. So getting a dead drive is a bit unusual, but it does happen. There's no way to tell if that was due to a manufacturing defect, or if the drive was somehow mishandled during shipment.
Since you just purchased, I suggest simply exchanging it with the seller for another EXOS. Then you get a new drive with full warranty. If you do an RMA with Seagate you'll get a recertified drive with a much shorter warranty.
May 04, 2020Guru - Experienced User
sebastianci wrote:
do you reckon I can test the drive with Seatools PC before I reinsert it to the NAS ( do not know if Seatools leave something on the drive what will prevent NAS from using it).
The NAS will reformat the disk anyway, so no worries there.
Start with the quick test, as it will give you some idea if the drive is working at all. Passing this test isn't enough to tell you that the drive is healthy.
Then move on to the long non-destructive read test. If this passes, then I suggest running the destructive full write test (which zeros the drive). The write test will sometimes pick up issues that the read test doesn't (and vice versa).
sebastianci
May 04, 2020Aspirant
Great ,
Thanks for that will start with seatools as my NAS is still rebuilding.
Sebastian
- SamirDMay 31, 2020Prodigy
Any news on how this went? I have an 8TB Exos too. :)
- sebastianciJun 05, 2020Aspirant
HI
Sorry for late update .
StephenBbig thanks to you, the disk was faulty, it was not recognized in any other PC, returned it and got full refund. I would never expect enterprise grade disk to be sold faulty ( you expect enterprise to be extra tested but there you go)
SamirDHi, are you having problems with the disk? I wonder if it is wise decission to go fo the same disk again?
Thanks
Sebastian
- SamirDJun 05, 2020Prodigy
I got my drive open box and crystal disk said it has issues, but it passes wd's tests fine and I'm running seagates on it now. It's an intermittent failure I think as I hear what sounds like the 'click of death' and then goes away. Luckily full warranty so if I have to rma it I will.
And I just saw the results of telling it to do an 'erase' in seatools and it failed. I'm running a 'long generic' test on it now and will expect that to fail too. That will convince me that it's bad so rma time in the morning. :)
