sebastianci
May 03, 2020Aspirant
RN104 not recognizing Seagate Exos 7E8 8TB
Hi My setup: RN104 bay 1 4TB WDC WD40 EFRX- 68WTONO bay 2 6TB ST6000NE0023-2EX110 bay 3 4TB WDC WD40 EFRX- 68WTONO bay 4 6TB ST6000NE0023-2EX110 X-RAID, RAID 5, Firmware 6.10.3 I have tried to...
- Jun 05, 2020
sebastianci wrote:
What is the conclusion, is EXOS 7E8 8TB are just bad ? From your experience do you see more issues with these than any other disks?
Thinking if it is worth buying another one? If true what you recommend for 8TB?
I haven't seen many posts here on the EXOS. Generally people seem happy with Seagate NAS-purposed (IronWolf) and enterprise class drives. DM drives aren't good choices (older ones had high failure rates in RAID, and some newer ones are SMR).
Generally I've gone with Western Digital, and I have sometimes received drives that were dead-on-arrival. So getting a dead drive is a bit unusual, but it does happen. There's no way to tell if that was due to a manufacturing defect, or if the drive was somehow mishandled during shipment.
Since you just purchased, I suggest simply exchanging it with the seller for another EXOS. Then you get a new drive with full warranty. If you do an RMA with Seagate you'll get a recertified drive with a much shorter warranty.
SamirD
Jun 06, 2020Prodigy
The EXOS is the enterprise line, this particular drive is the basic 7200rpm 2.5M MTBF 5yr warranty variety without any of the other features like full encryption or fips or anything like that.
I have a lot of WD as well as HGST drives as well. I usually pick up drives that are deeply discounted through authorized distributors (usually open-box returns). They come with a full warranty, but sometimes may have been returned for an intermittent problem that didn't show up when the returns processing checked it before listing it. In these cases, it's just a simple warranty issue--which by the way, a warranteed drive gets the remainder of the original warranty so you don't lose anything. And in fact, if a drive is about to go out of warranty, the replacement drive will have either the remainer of the existing warranty or 90 days, whichever is more.
Sometimes these drives also get banged around a bit from improper packaging since they usually do not have the original packaging. I don't think that was the case for this drive and didn't know if there was an issue with these drives and the ReadyNas as I know certain nas units are picky (ahem...synology...ahem...).
I ran tests on the drive with a computer and seatools after removing it from the ReadyNas and it failed some tests, so I'm sending it back for replacment. I plan to try the replacment in the ReadyNas and expect it to work well this time as the previous drive would work intermittently.
sebastianci
Jun 13, 2020Aspirant
Hi sorry to reopen the case,
I got brand new EXOS 7E8 8TB , but this time I have not inserted it to NAS but connected to PC and run :
crystal - OK
seatools all ok apart from SCT Write Same Erase test , it fails after approx a minute. Do you reckon it is something wrong with Seatools or I am super unlucky and got second bad drive in a row? What do you think?
------- SeaTools for Windows v1.4.0.7 ---------------
10/06/2020 18:52:54
Model Number: ST8000NM000A-2KE101
Serial Number: WKD1GQWF
Firmware Revision: SN02
SMART - Started 10/06/2020 18:52:54
SMART - Pass 10/06/2020 18:53:00
Short DST - Started 10/06/2020 18:53:50
Short DST - Pass 10/06/2020 18:54:52
Identify - Started 10/06/2020 18:55:11
Long Generic - Started 10/06/2020 18:55:39
Long Generic - Pass 11/06/2020 05:56:24
Long Generic - Started 11/06/2020 07:04:32
SCT Write Same Erase - Started 11/06/2020 07:07:38
SCT Write Same Erase - FAIL 11/06/2020 07:54:15
Overwrite Erase - Started 11/06/2020 09:03:02
Overwrite Erase - Pass 11/06/2020 20:10:47
Fix All Long - Started 12/06/2020 10:16:24
Fix All Long - Pass 12/06/2020 21:23:17
SCT Write Same Erase - Started 13/06/2020 09:57:33
SCT Write Same Erase - FAIL 13/06/2020 09:58:46
- StephenBJun 13, 2020Guru - Experienced User
Fix All Long - Pass 12/06/2020 21:23:17Personally I wouldn't have run this, as I don't actually want Seatools to try to "fix" a new drive (or really any drive).
sebastianci wrote:I got brand new EXOS 7E8 8TB , but this time I have not inserted it to NAS but connected to PC and run :
crystal - OK
SCT Write Same Erase - FAIL 11/06/2020 07:54:15...
SCT Write Same Erase - FAIL 13/06/2020 09:58:46How is the drive connected to the PC? Are you using SATA, or a USB adapter?
Since it passed the full overwrite erase and the long read test, I am thinking it might be an issue with the setup, and not the drive.
But I am a bit worried, as the first "same erase" test ran nearly an hour, unlike the second one, which ran less than a minute. You could contact Seagate as they must have seen this before. Maybe in the meantime, run another short test and another full erase overwrite, and confirm that they still pass.
As a reminder, you don't want to RMA the drive to seagate - if it does turn out to be bad, you do want to exchange it instead.
- sebastianciJun 13, 2020Aspirant
Thanks
Drive is connected to SATA on the mother board.
Yes I run "fix" as I thought that some bad sectors need fixing for SCT test.
Will create case for segate and let you know the outcome., Short generic has passed, long Overwrite Erase is going on.
Thanks
- SamirDJun 13, 2020Prodigy
Sounds like you got a second bad drive that sounds like it's mine, lol. (Can't be though since Seagate hasn't gotten mine yet. :))
I would simply exchange it again if you're running it straight sata in a computer and are running into these issues, even if intermittent.
- sebastianciJul 02, 2020Aspirant
Case confirmed by CCL: SECOND FAULTY EXOS drive in a row! I will get full refund. It looks at least for this line of drives quality control of Segate is poor. I will not be going for exos anymore, thanks for help.
- SamirDJul 10, 2020Prodigy
Hey, it's not just you! My replacement 8tb sounded like it was crunching when I first powered it up in a drive dock to see if it would spin up. This wouldn't happen if they wouldn't just use the same box as it comes in off the pallet. A pallet of drives like this will survive bumps, but shipping individual units that will be thrown--no way!
While I was waiting for my 8TB, I found a deal on a 12TB exos. Works like a charm on 4.2.28 showing 0% of 10TB used on the front page, and showing 11176GB in health status as well as "11,885,420,335,104 bytes free". :) Can't wait to get my other drive back and pair it with this one and see what happens. :D
