sebastianci
May 03, 2020Aspirant
RN104 not recognizing Seagate Exos 7E8 8TB
Hi My setup: RN104 bay 1 4TB WDC WD40 EFRX- 68WTONO bay 2 6TB ST6000NE0023-2EX110 bay 3 4TB WDC WD40 EFRX- 68WTONO bay 4 6TB ST6000NE0023-2EX110 X-RAID, RAID 5, Firmware 6.10.3 I have tried to...
- Jun 05, 2020
sebastianci wrote:
What is the conclusion, is EXOS 7E8 8TB are just bad ? From your experience do you see more issues with these than any other disks?
Thinking if it is worth buying another one? If true what you recommend for 8TB?
I haven't seen many posts here on the EXOS. Generally people seem happy with Seagate NAS-purposed (IronWolf) and enterprise class drives. DM drives aren't good choices (older ones had high failure rates in RAID, and some newer ones are SMR).
Generally I've gone with Western Digital, and I have sometimes received drives that were dead-on-arrival. So getting a dead drive is a bit unusual, but it does happen. There's no way to tell if that was due to a manufacturing defect, or if the drive was somehow mishandled during shipment.
Since you just purchased, I suggest simply exchanging it with the seller for another EXOS. Then you get a new drive with full warranty. If you do an RMA with Seagate you'll get a recertified drive with a much shorter warranty.
sebastianci
Jun 13, 2020Aspirant
Hi sorry to reopen the case,
I got brand new EXOS 7E8 8TB , but this time I have not inserted it to NAS but connected to PC and run :
crystal - OK
seatools all ok apart from SCT Write Same Erase test , it fails after approx a minute. Do you reckon it is something wrong with Seatools or I am super unlucky and got second bad drive in a row? What do you think?
------- SeaTools for Windows v1.4.0.7 ---------------
10/06/2020 18:52:54
Model Number: ST8000NM000A-2KE101
Serial Number: WKD1GQWF
Firmware Revision: SN02
SMART - Started 10/06/2020 18:52:54
SMART - Pass 10/06/2020 18:53:00
Short DST - Started 10/06/2020 18:53:50
Short DST - Pass 10/06/2020 18:54:52
Identify - Started 10/06/2020 18:55:11
Long Generic - Started 10/06/2020 18:55:39
Long Generic - Pass 11/06/2020 05:56:24
Long Generic - Started 11/06/2020 07:04:32
SCT Write Same Erase - Started 11/06/2020 07:07:38
SCT Write Same Erase - FAIL 11/06/2020 07:54:15
Overwrite Erase - Started 11/06/2020 09:03:02
Overwrite Erase - Pass 11/06/2020 20:10:47
Fix All Long - Started 12/06/2020 10:16:24
Fix All Long - Pass 12/06/2020 21:23:17
SCT Write Same Erase - Started 13/06/2020 09:57:33
SCT Write Same Erase - FAIL 13/06/2020 09:58:46
sebastianci
Thanks
Drive is connected to SATA on the mother board.
Yes I run "fix" as I thought that some bad sectors need fixing for SCT test.
Will create case for segate and let you know the outcome., Short generic has passed, long Overwrite Erase is going on.
Thanks
- SamirDJun 13, 2020Prodigy
Sounds like you got a second bad drive that sounds like it's mine, lol. (Can't be though since Seagate hasn't gotten mine yet. :))
I would simply exchange it again if you're running it straight sata in a computer and are running into these issues, even if intermittent.
- sebastianciJul 02, 2020Aspirant
Case confirmed by CCL: SECOND FAULTY EXOS drive in a row! I will get full refund. It looks at least for this line of drives quality control of Segate is poor. I will not be going for exos anymore, thanks for help.
- SamirDJul 10, 2020Prodigy
Hey, it's not just you! My replacement 8tb sounded like it was crunching when I first powered it up in a drive dock to see if it would spin up. This wouldn't happen if they wouldn't just use the same box as it comes in off the pallet. A pallet of drives like this will survive bumps, but shipping individual units that will be thrown--no way!
While I was waiting for my 8TB, I found a deal on a 12TB exos. Works like a charm on 4.2.28 showing 0% of 10TB used on the front page, and showing 11176GB in health status as well as "11,885,420,335,104 bytes free". :) Can't wait to get my other drive back and pair it with this one and see what happens. :D
