Astra03
Jul 24, 2020Star
RN214 Failing to Update Antivirus
Hi, For the past week I have been getting a daily alert "System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection." I have found a number of o...
Jul 25, 2020Guru - Experienced User
Astra03 wrote:A partition only 50% full causing issues seems very low to me - is that to be expected?
As I tried to say above, I don't think the 50% fullness is causing your AV problem. If it stays at about 50%, it shouldn't cause any problem at all. But if the space is growing, it will create other problems when it gets full. The OS partition is only 4 GB, so you do need to be careful on what you put there.
Shifting stuff is fairly easy - you copy the folder with the appropriate cp command, and then replace the folder with a link using ln. You can play with this on your desktop first, to make sure you have the commands down.
And if you simply check with du, you should be able to find out what apps are using up the space.
Astra03 wrote:
l, I can SSH into the ReadyNAS, type "freshclam", the update downloads and installs, and is seen by the NAS' overview screen and logs and everything is OK - until the next day, when the same issue repeats? Is this not an issue with the way the OS is trying to do the update>
Others have also reported that freshclam works. I am wondering if the NAS is looking for an update to the software, and not just a new virus definition. You might try looking through the logs for more details on what is going wrong.
Astra03
Jul 25, 2020Star
Thanks again for your assistance, but I do not understand how to use the information that you are giving me. "cp" to copy a file to a new location I am fine with, but how exactly do I use "ln" to create a link? (I have never done that before). Also, if I SSH into the NAS as root and type "du" I get back:
12 ./.ssh
36 .
What is this telling me, or am I using the command incorrectly? (I also tried "cd" to /dev/md0/ and again "du" gave me the same response.
If the available space in the md0 partition is not the real issue, and given that I can daily manually update the AV by using "freshclam", is it possible to automate that process with some sort of script? If so, how would I do that? I am vaguely aware of cron jobs (?), but do not know how to create one for a task such as this.
Paul
- Astra03Jul 25, 2020Star
Once again, the daily AV update has failed - and once again logging in and manually "freshclam" has temporarily resolved the issue. Can this daily "freshclam" task be automated seperately from the OS task that always fails?
- StephenBJul 25, 2020Guru - Experienced User
Astra03 wrote:
12 ./.ssh
36 .
What you need to do is begin by entering
# mount --bind / /mnt
# cd /mntThere are several mount points in the actual OS partition that get in the way of analyzing space - for instance /data and /apps. The first command remounts the OS partition as /mnt.
Once there, there are several commands that will show you the space usage. One is
# du -d1 -h
Which will show you the space in each top-level folder. You can then descend into the bigger ones, and repeat that command. For instance, on my own NAS I see
root@RN202:~# cd /mnt
root@RN202:/mnt# du -d1 -h
6.0M ./bin
4.0K ./proc
4.0K ./boot
11M ./sbin
24K ./tmp
16K ./lost+found
4.0K ./run
31M ./frontview
4.0K ./sys
12K ./dev
8.8M ./etc
4.0K ./media
3.9M ./opt
4.0K ./apps
4.0K ./mnt
4.0K ./data
4.0K ./home
206M ./usr
29M ./lib
235M ./var
32K ./root
4.0K ./srv
529M .You can see that normally almost all the space is in /var and /usr. If we descend in /var, you'd see
root@RN202:/mnt# cd var
root@RN202:/mnt/var# du -d1 -h
49M ./log
4.0K ./tmp
8.7M ./readynasd
4.0K ./cores
76M ./cache
8.0K ./www
16K ./netatalk
4.0K ./opt
4.0K ./ftp
4.0K ./mail
17M ./backups
86M ./lib
16K ./spool
4.0K ./local
235M .
root@RN202:/mnt/var#Similarly for usr
root@RN202:/mnt/var# cd ../usr root@RN202:/mnt/usr# du -d1 -h 36M ./bin 4.0K ./games 25M ./sbin 4.0K ./include 37M ./share 109M ./lib 4.0K ./src 44K ./local 206M . root@RN202:/mnt/usr#
When done, enter
# cd // # umount /mnt
The last command (easy to mistype as unmount) will undo the mount. You have to navigate out of the /mnt folder before you enter it (otherwise it will fail)
You could automate it, but I am thinking it would be better to look in the logs and see if you can get a better handle on the cause of the problem. You might want to look in
- apt-history.log
- dmesg.log
- system.log
Not sure if there is a separate log for ClamAV (it's not something I have turned on).
- Astra03Jul 26, 2020Star
Thanks once again for your reply. This is what I have found:
root@M***h-Server:~# cd /mnt
root@M***h-Server:/mnt# du -d1 -h
4.0K ./mnt
4.0K ./boot
4.0K ./home
36K ./root
4.0K ./apps
31M ./frontview
4.0K ./proc
6.0M ./bin
16K ./lost+found
451M ./usr
58M ./lib
12K ./dev
9.4M ./etc
4.0K ./srv
8.0K ./media
4.1M ./opt
4.0K ./run
28K ./tmp
1.2G ./var
11M ./sbin
4.0K ./sys
4.0K ./data
1.7G .As you said, /usr and /var are by far the largest top level folders and descending down into the file system breaks these down further.
So, I think I know how to copy a folder to the /data partition to reduce space, (cp "copy" or mv "move" if I am trying to reduce space usage?), but what I do not know how to do is use ln to create symbolic links to the new folder locations. Can you help me with that please?
I have been unable to find any of the three log files that you mentioned - I tried using the Linux "find" command, but got back "No such file or directory" for each of them. There is a folder /var/log/clamav , but "ls" does not return any contents.
Paul
- StephenBJul 26, 2020Guru - Experienced User
The log is accessed via ssh with journalctl. While I do sometimes do that, it generally works out better if you have a keyword to search for. Then you can pipe it through grep. For instance
# journalctl -r --no-pager | grep -i error
will give you all journal entries that have the word "error" in them.
Adding -k to the journalctl command will limit the output to kernel entries. Journalctl does have filters built into it (an alternative to grep), but mostly I just use grep. https://manpages.debian.org/stretch/systemd/journalctl.1.en.html
I was suggesting that you download the log zip file from the NAS web ui - the files I suggested are in the zip.
There is a lot of help for most linux commands out there if you just google the command name with "linux" (perhaps also adding "man").
Here are two:
It's really best to look through the man pages and examples, and try them on your linux desktop. Trying them directly on the NAS does have some risk - you can easily end up with an unbootable NAS, or with data loss.
Also, you want to ssh into the NAS as root (using the NAS admin password).
That said: what you want in this case is a "soft link".
ReadyNAS apps are supposed to put their data on the data volume. If you use the default data volume name ("data"), then the app data is in a subfolder of /data/.apps
Note that .apps is a hidden folder - so you won't see it with ls /data but you will see it with ls -a /data.
I suggest creating a relocation folder in .apps (perhaps /data/.apps/relocate) and then copy the folders into relocate. Alternatively you can create a relocation folder for each app (e.g., /data/.apps/LMS, etc).
But let's say the folder you want to relocate is /var/myfolder and that you've already moved it to /data/.apps/relocate/myfolder.
Then you create the soft link with
ln -s /data/.apps/relocate/myfolder /var/myfolder
Remember that you put the target first (which I find non-intuitive). And it's important to create a soft link (-s) and not the default hard link.
You might want to try this sequence to get the hang of it:
# mkdir /data/.apps/relocate # mkdir /data/.apps/relocate/myfolder # mkdir /data/.apps/relocate/myfolder/temp # ln -s /data/.apps/relocate/myfolder
Now if you look at /var you'll see the soft link
root@RN202:/var# ls -al /var/myfolder lrwxrwxrwx 1 root root 29 Jul 26 06:26 /var/myfolder -> /data/.apps/relocate/myfolder
And if you navigate into /var/myfolder, you'll see that you appear to be in /var/myfolder but you are seeing the files and folders in the target /data/.apps/relocate/myfolder. In this example, the temp folder you created above.
# root@RN202:/var# cd myfolder
# root@RN202:/var/myfolder# ls -al total 0 drwxr-xr-x 1 root root 8 Jul 26 06:26 . drwxr-xr-x 1 root root 16 Jul 26 06:24 .. drwxr-xr-x 1 root root 0 Jul 26 06:26 temp root@RN202:/var/myfolder#Note that /var/myfolder is deleted as if it is an ordinary file - not a folder. That's because a soft link is a file.
# root@RN202:/var# rm myfolder
To delete the relocated target you'd need to use -r (or rmdir if it is empty).
# rm -r /data/.apps/relocate/myfolder
Hi,
I'm going to try look in to this in more detail later, but tried journalctl -r --no-pager | grep -i error as you suggested. The first 3 lines from the output look to be relevant to my problem:
Jul 25 18:47:59 Marsh-Server freshclam[30956]: During database load : ERROR: Failed to load new database: Malformed database
Jul 25 18:47:59 Marsh-Server freshclam[30956]: ERROR: Failed to load new database
Jul 25 18:47:59 Marsh-Server freshclam[30956]: ERROR: During database load : ERROR: Failed to load new database: Malformed databaseThere are similar entries daily for the past week - when this issue first started. 18:47 is the same time that I receive the system generated email advising of the failure. Each day I then SSH i, and a manual "freshclam" appears to resolve the problem - for 24 hours.
Does "Malformed database" sugest that there is a corrupted file somewhere? Is it the file that the automated procedure is trying to download and install? If that is the case, what is the difference between the automated process which always fails, and my manual "freshclam" which always works?
Given that a daily manual freshclam always seems to work, is there really any need to start moving system files and creating links - with all the work, (and risks), involved if I do get it wrong?
I've already answered that (at least twice). 50% OS partition fullness is higher than it should be but shouldn't cause any immediate problems. You do want to make sure it isn't continuing to grow. It would be useful to know what app is using the space.
But there's no immediate need to relocate anything. As I've also said, relocating folders won't solve your antivirus issue.
Can you post the output you see when you run freshclam manually? Perhaps use freshclam -v --debug
You might also want to try a small antivirus scan. clamscan -r -v --debug /data/sharename should do it. Choose a small share.
Also, look in the log zip (in the files I mentioned earlier) to get more details on what happened around Jul 25 18:47:59. Likely there are more entries that don't include the word error.
BTW, are you logging in as root when you run freshclam? You should be.
- Astra03Jul 27, 2020Star
Well now, this is interesting.
Yesterday evening, (Sunday 26th), I decided to reboot the NAS and also then stop and restart the AntiVirus in the ReadyNAS' GUI - I had previously tried just rebooting the NAS a few times as this had been found to work for some users, although temporarily. The AV did not immediately try to update itself, so I forced it manually with "freshclam". This evening, (Monday 27th), I noticed that I had not received the now daily "AV download failed" email, so I logged on to the ReadyNAS and found that it had updated itself - for the first time in over a week!
Obviously, what I don't know is whether my actions caused this to happen, or something external has changed in the past 24 hours or so? I'm now going to monitor it daily to see what happens.
I did not get a chance to try out your final suggestions, but if nothing else I have learnt a few new Linux commands, (New to me anyway), so thanks for that!
Paul
