Astra03
Jul 24, 2020Apprentice
RN214 Failing to Update Antivirus
Hi, For the past week I have been getting a daily alert "System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection." I have found a number of o...
AdriFrijters
Feb 16, 2021Tutor
Astra03 , and others,
Did you refer to the text below?
Ok, I can read but don’t understand what to do.
This is far above the knowledge I have.
I know a lot on occupational safety but nothing on software, I am a simple user.
So, who can help me?
Apprentice
2020-07-29 01:03 AM
Re: Antivirus scanner definition file update failed
That's why I added FRESHCLAM to the CRONTAB; once a day updating my virus-definitions.
short description how to add:
open a SSH-session with your NAS and logon with userid: root
enter command: crontab -e
move your cursor to the last letter in the file and enter: o
put in next line: 5 21 * * * /usr/bin/freshclam
enter: shift+zz
and now every day at 5 minutes past nine FRESHCLAM will run
Astra03
Feb 16, 2021Apprentice
I'm no expert either, but I'll try to help!
Firstly, do you have SSH enabled on your RN214? From the devices's Admin homepage > System > Settings, then under Services, SSH should be green. If it is not, then activate it.
Also, what operating system are you using on your desktop / laptop PC? I use Linux, so if you use Windows or Mac etc someone else may have to jump in with the differences.
Post back when you have SSH enabled :smileyhappy:
