HansPirmo's avatar
HansPirmo
RND2000 Duov2 - OS reinstall - Password
I am now the owner of a ReadyNAS RND2000 Duo v2which gives me some problems. I have tried to boot the unit with only 1 drive inside using the boot description from your homepage using a clip and hold...
  • StephenB's avatar
    Sep 14, 2017
    HansPirmo wrote:
    It is a little difficult, as the buttomlabel says:
    NETGEAR ReadyNAS Duo RND2000 v2
    That label is misleading.  The v2 means "hardware revision 2 of the duo v1".  If you have a v2, then the front panel would say duo v2.
    The default password on the duo v1 is netgear1 not password.
    The boot menu instructions are also different - here's a link to the hardware manual:  http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf  The boot menu is described on pages 15-16.
ProSupport for Business
