mfb9
Apr 25, 2019Aspirant
RND4000 v3 (ReadyNAS NV+) RAID 1
Hello. Newly purchased ReadyNAS NV+ v3, to be used as media server mostly. Flex-RAID, two volumes RAID 1, currently 4 x 1TB discs. I had backed everything up onto a 2TB disk, and bought a second 2...
Apr 28, 2019Guru - Experienced User
mfb9 wrote:
Actually, on second thoughts, look what I've found! The clear implication is that it will do as I was hoping for.
No, that's not the clear implication. The section you are quoting is for XRAID, not FlexRAID.
mfb9
Apr 28, 2019Aspirant
Oh! It seemed to be in the Flex-RAID section, and it refers to RAID 1 specifically, which isn't a feature of X-RAID... I'll try it anyway.
Thanks for your help.
Mark
Mark
- StephenBApr 28, 2019Guru - Experienced User
mfb9 wrote:
Oh! It seemed to be in the Flex-RAID section, and it refers to RAID 1 specifically, which isn't a feature of X-RAID...XRAID on your NAS will use RAID-1 if there are only two disks in the volume.
Looking again, the snippet does seem to be in the FlexRaid section. Anyway, hopefully it will expand.
