YE7
May 24, 2017Aspirant
SMB disabled
Hi, I have upgraded the firmware on a RN42200 from 6.7.1 to 6.7.3 and that caused it to loose SMB service. When I click on SMB service to enable it, I hit apply and nothing happens. Thanks, ...
jak0lantash
May 24, 2017Mentor
Before OS Reinstall, try to confirm that you're not in a full root situation.
Download the logs from the GUI, look at the end of volume.log, there is a section with "df -h" and confirm that the line with md0 doesn't show the volume 100% full.
YE7
This is the "df -h" infro from the volume log:
I don't think it's full.
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 804M 2.9G 22% / tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs 3.9G 7.4M 3.9G 1% /run tmpfs 2.0G 28K 2.0G 1% /run/lock tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup /dev/md127 20T 17T 3.0T 85% /data /dev/md127 20T 17T 3.0T 85% /home /dev/md127 20T 17T 3.0T 85% /apps /dev/md127 20T 17T 3.0T 85% /var/ftp/Barracuda /dev/md127 20T 17T 3.0T 85% /run/nfs4/data/Backup /dev/md127 20T 17T 3.0T 85% /run/nfs4/data/Backup2Disk === df -i === Filesystem Inodes IUsed IFree IUse% Mounted on udev 1005843 681 1005162 1% /dev /dev/md0 0 0 0 - / tmpfs 1006497 1 1006496 1% /dev/shm tmpfs 1006497 981 1005516 1% /run tmpfs 1006497 7 1006490 1% /run/lock tmpfs 1006497 11 1006486 1% /sys/fs/cgroup /dev/md127 0 0 0 - /data /dev/md127 0 0 0 - /home /dev/md127 0 0 0 - /apps /dev/md127 0 0 0 - /var/ftp/Barracuda /dev/md127 0 0 0 - /run/nfs4/data/Backup /dev/md127 0 0 0 - /run/nfs4/data/Backup2Disk
- jak0lantashMay 24, 2017Mentor
YE7 wrote:I don't think it's full.
=== df -h === Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 804M 2.9G 22% /
No, it's not full.
