cboudet
Oct 24, 2022Aspirant
Unable to find readynas duo rnd 2110 v2 on my network and unable to reset to factory settings
Hello, I have a readynas duo rnd 2110 v2 that seems to boot up fine, led's are lit not flashing, but I cannot find it in my network. I have attempted to find it using raidar, and advanced network ...
- Oct 27, 2022
- StephenB
Success!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I want to thank you because without your help, I would have given up a long time ago.
This nas frustrated me for a couple of weeks straight, but I don't give up easily.
This is what I did in case it helps anyone else.
I had to get an old router and configure it with a static ip of 192.168.168.1 and enable dhcp on it.
Then i configured my laptop to accept dhcp ip assignment and I connected it to the router.
I did an os reinstall on the nas with just disk one and then I connected it to the router.
I started raidar and it found the nas right away, and the setup button was not greyed out.
I got an error about the browser and had to enable my old internet explorer as the default browser, and after that raidar was able to open the frontview interface.
I could not use the browser to set it up and had to use raidar.
I cannot thank you enough for sticking with me and all my questions.
God bless you!
Oct 25, 2022Guru - Experienced User
The issue with RAIDar might be caused by security software on the PC
cboudet wrote:
Last night I found out why I had not been able to reset the nas.
The label at the bottom said it was an rnd 2110 v2 , so I thought it was version 2 but it is a version 1 readynas duo and the reset procedure is a little different for it.
Yes, the procedures are different (and the labeling is confusing). Note if you did the factory default procedure, the system would reformat the disks - so you would lose all the data. Hopefully you actually did an "OS reinstall".
cboudet wrote:
I tried through the browser using 192.168.168.168 and still cannot connect.
That is because you have a 10.0.0.x network. It is possible to connect the NAS directly to a PC over ethernet (with no router). But if you do that, you also need to manually configure the network on the PC before you can connect.
You can get to the settings in Win10 by
- going to "network and internet" in the control panel
- Select "change adapter settings"
- Select the ethernet adapter
- select "change settings of this connection"
- Select "Internet Protocol Version 4 (TCP/IPv4)
- click on "properties"
From there, select the "alternate configuration" tab. and fill it out like this:
Then you can browse to https://192.168.168.168/admin
However, there was a change in the internet browsers a few months ago that will get in the way. Your NAS uses TLS 1.0 for HTTPS connections, and browsers now require TLS 1.2. Chrome, Firefox, Edge, etc will give you an SSL protocol error and/or a Cipher mismatch when you try to reach frontview.
You can
- Use Internet Explorer if that is installed on the PC
- Use Edge in IE mode ( see https://pureinfotech.com/enable-ie-mode-microsoft-edge-chromium/ )
- Download an old version of Firefox (94.0.2 works), and configure it to not auto-update. Then use FireFox to access the NAS
cboudet
Oct 25, 2022Aspirant
Thanks so much for the help.
I connected it to the laptop before and after I connected it to my home network.
before, I used a set ip as you suggested, and after I used the ip assigned by my home router.
In both cases I could not find the NAS with neither RAIDAR nor browser.
I don't know what else to do.
I have disabled the firewall and uninstalled my virus scanner.
I don't know how to do the permissions or security stuff other than what I did, which may not be a good idea.
Thanks again
