davidtheo
Jul 10, 2023Aspirant
Unable to log into my RN10400
Does anyone know why I can not log into my RN10400 nas drive any more, I know this is not the forum for nas drives but seems the NAS drive forum is not working anymore.
- Jul 11, 2023
Your post is in the right forum (perhaps Netgear moved it).
If you normally use ReadyCloud, then the issue is that Netgear has taken it down.
If not, do you mean that you can't log into the NAS admin web interface? Or that you cannot access the shares using File Explorer (or Finder)?
Jul 11, 2023Guru - Experienced User
davidtheo wrote:
Hi my Issue is with ReadyCloud. Do you know if they are going to replace it?
No hints that they will (and I'd be very surprised if they do). All indications here are that they are dropping ReadyNAS products.
I use OpenVPN (hosted in my Orbi router) instead. If you want to share files, then I'd suggest putting something like OneCloud or NextCloud on a PC that has a NAS share mounted as a drive letter.
davidtheo
Jul 11, 2023Aspirant
Thanks for your help.
Shame they have done this.
