a20rju
Dec 16, 2016Aspirant
Re-use old REadyNAs HDD's
Hi, I got a 1TB drive that was in use on my old ReadyNAS Duo (RND2000 V2). Deciding that it is more useful in a PC, I've connected it internally to a newly built Windows 10 PC. But, It shows up in D...
aalexandrebeta
Feb 11, 2017Master
StephenBThis is the procedure I always use to recycle my HDD to be reused on ReadyNas devices but Windows reformat stuff is suficient.
Feb 11, 2017Guru - Experienced User
aalexandrebeta wrote:
StephenB This is the procedure I always use to recycle my HDD to be reused on ReadyNas devices but Windows reformat stuff is suficient.
OS 6 NAS won't add a formatted drive to the RAID array w/o confimation. They will add unformatted drives immediately (which sometimes is a bit simpler).
One way to unformat a drive is to use the quick zeros write test in Lifeguard. Another is to delete each "volume" on the disk with the windows disk manager (which deletes the partitions).
- aalexandrebetaFeb 11, 2017Master
StephenB I really prefer a clean in order to avoid issues when the device rebuild the array!!!
- StephenBFeb 11, 2017Guru - Experienced User
I'm not sure if you are agreeing or not. Unformating and the quick zeros test will both result in the ReadyNAS treating the disk as a blank drive. If you are uncertain of the drive health, run the full write zeros test.
StephenB I do agree with you zero write is for me the best solution:
The more you avoid issues the less issues you have!
