LesZ
Aug 01, 2017Aspirant
Volume lost after failed drive replacement trying to recover data
Firmware 6.7.5. MY unit is set up in X-Raid. All 6 drives are 4TB Wester Digital WD4000FYYZ including hte new replacement drive. I have two issues. 1. Drive #6 failed. I have replace it and f...
xiao123
Aug 16, 2017NETGEAR Expert
LesZ wrote:
I first installed the drive unformated and it did not rebuild. I then formated from the admin UI still no joy.
I have downloaded the logs and under disk_info I see channel 0, 1, 3, 4, 5. Could this be a dead slot?
Hi LesZ,
What mode of your nas? How did you unplug the disks, remove one at a time or two at a time ?
LesZ
Aug 16, 2017Aspirant
Thanks for replying but it has been long enough that I reformated the drive from the ground up.
