laurensat101's avatar
laurensat101
ReadayNAS Ultra 4 data recovery after dying
My 2011 Netgear Readynas Ultra 4 blew out the electricity and died recently. Either the PSU or the entire thing died. Inside were 4 disk with valuable data, in Raid 5.
The question would be, if I  buy a 4-hdd docking station, can I recover the data on it with a raid recovery software? Or does anyone have a better idea?
Replacing the PSU is something I could only find on ebay for a lot of money. And plugging in another normal PSU is something a bit over my head
Hope someone has a good tip to get my data off,
#readynas ultra 4
  • StephenB's avatar
    Were you running the stock 4.2.x firmware?
    Or had you converted the NAS to run OS 6?
    • laurensat101's avatar
      laurensat101
      I'm afraid I can't recall, it's been a while since I had updated it, that's for sure. But it blew up after I had not touched it in a while, could you help me with the implication of either OS?
      But I'm guessing 4.2
      • Sandshark's avatar
        Sandshark
        Sensei
        Do you have a saved copy of a log file?  That will tell you which you were using.
        The recovery methods are quite different because of the different volume structures used (LVM/MDADM and GPT for 4.2 and MDADM and BTRFS on OS6).
        The easiest recovery method, assuming the volume was not damaged when the unit "blew up" (which will affect any recovery method) is to put the drives in a replacement ReadyNAS.  But you'll also need to know which OS you were running to do that.  And, of course, you'd be buying used equipment, which always carries some risk.  And there is the question as to whether you want to continue using a NAS from a company that has basically abandoned it.
ProSupport for Business
