confused_wookie
Sep 12, 2013Follower
ReadNAS Duo v2 HDD missing
Hello, I have a ready nas here that is giving me some trouble. When I log into the web console it seems that one HDD is not being read by the device, drive #2. On the physical device its self, there a...
vandermerwe
Sep 12, 2013Master
Could you tell us how your NAS is setup, are you running xraid or raid1, or are you running 2 separate volumes on separate disks, ie a non-redundant volume.
What firmware are you running?
Do you have another copy of the data on the NAS?
Have you received any error messages about disks recently?
Can you read the smart information from the disks?
If the smart info is ok, I would suggest powering down and testing the disks using vendor tools.
The backups you refer to: why do you think is relevant to your problem?
