Guardshell
Oct 05, 2020Aspirant
Ready NAD Duo wiped drives and factory reset on its own
Hi I have a ready nas duo v2 and 2x 2tb Wesatern digital drives installed ive had this for about 8-9 years and today I went to connect to the NAS and the IP had changed from the usual 192.168.1....
Oct 05, 2020Guru - Experienced User
What firmware are you running?
Have you downloaded the log zip file and looked for clues?
- GuardshellOct 05, 2020Aspirant
Test
StephenB wrote:What firmware are you running?
Its the latest firmware all I can see is that it decided to wipe everything on the 21st september no information why
Sep 21 14:44:53 nas-BE-F8-F4 syslogd 1.5.0#6: restart.
Sep 21 14:44:53 nas-BE-F8-F4 kernel: klogd 1.5.0#6, log source = /proc/kmsg started.
Sep 21 14:44:53 nas-BE-F8-F4 kernel: Linux version 2.6.31.8.duov2 (root@NSBU-NJ) (gcc version 4.3.2 (sdk3.2rc1-ct-ng-1.4.1) ) #1 Thu Apr 18 18:24:47 HKT 2013
Sep 21 14:44:53 nas-BE-F8-F4 kernel: CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977
Sep 21 14:44:53 nas-BE-F8-F4 kernel: CPU: VIVT data cache, VIVT instruction cache- StephenBOct 05, 2020Guru - Experienced User
Your earlier responses got trapped in the automatic spam filter - I released the most recent.
Sep 21 14:44:53 nas-BE-F8-F4 kernel: CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977My reason for asking was to confirm that you had an NV+ v2 - a lot of v1 owners mistakenly think they have a v2.
"Latest" of course isn't helpful. But the log entry saying you have an arm processor confirms that you are in fact have a v2.
Sep 21 14:44:53 nas-BE-F8-F4 kernel: CPU: VIVT data cache, VIVT instruction cacheThis shows a restart, but not a factory reset. Are there any log entries before this?
Are you seeing no data volume in the dashboard?
If there is a data volume, are you seeing just the default shares? Or are you seeing your older share configuration (assuming that it is different from the default)?
Was the admin password reset back to the default setting of password?
