paulgent
Jan 04, 2017Aspirant
Ready NAS 314 - Disk Fail - No Volumes Exist
Having been away fro 2 weeks I have returned today to find the NAS saying disk 4 degraded - I took the disk out and reseated it - and now the system takes about 10 minutes to book (raid 5 and encrypt...
mdgm-ntgr
Jan 05, 2017NETGEAR Employee Retired
You'd fill in the contact us form and then follow one of the options to turn it into a case.
paulgent
Jan 10, 2017Aspirant
After 3 days I have had NO REPLY from support and today when I try to put a new case in the web page errors :(
I have today purchased 2 new disks for the machine to see if I can re-build any of the drives - I first of all replaced Drive 3 to see if this would kick start a re-build - but nothing happened and then put back the old disk 3 and then replaced disk 4 - again nothing happened.
The box takes about 10 minutes to re-boot and the old directory structure shows via windows explorer but I can not access any of the folders
Can you help at all please - as support so far has been a complete non-starter
Paul
- mdgm-ntgrJan 10, 2017NETGEAR Employee Retired
I see no cases whatsoever have been opened for this device. Your purchase date is in the range for lifetime (online) chat support so you should choose the live chat option.
Trying to fix this problem yourself if it makes any difference is only likely to make it less likely that your data is recoverable. Blindly replacing the disks and hoping this will resolve a problem like this is not the solution. - paulgentJan 10, 2017Aspirant
Everytime I try and access online chat the link says unavailable
Are you using the account you registered the RN314 to?
