Garet
Oct 06, 2015Aspirant
Ready NAS 4220 terminal command to unset 'allow snapshot access' check box
I have a readynas 4220 acting as a fileserver, joined to a AD. Running Firmware 6.2.4 There is also a on-site file indexer running 24/7. It indexes 4 of the shares. I have a junior administrator...
- Oct 08, 2015
Thanks for looking into that for me.
I thought there might be a terminal command for that.
Garet
Oct 07, 2015Guru - Experienced User
I am puzzled on the use case. You want this cron job in order to guard against a mistake that might be made by a NAS administrator?
- kohdeeOct 08, 2015Administrator
There is no specific terminal command to turn off the snapshot access on a share since snapshot access, being enabled through the UI, is translated through the middleware.
My recommendation is to teach the junior administrator best practice is to return the system back to how it was once making the change. Maybe they can confirm snapshot access is turned off when closing a ticket.- GaretOct 08, 2015Aspirant
Garet
- StephenBOct 08, 2015Guru - Experienced User
I agree.
Though there used to be a way to access the snapshots from the full Data volume (even with access turned off). That seems to have disappeared. It was handy sometimes (and perhaps this use case is one example).
So maybe post a suggestion in the "ideas for storage" section, saying there should be a way for admins to directly access the snapshot folders even if the setting isn't checked.
ReadyNAS doesn't support the ability to snapshot the whole data volume from front-end controls, so that shouldn't have been possible to snapshot or view an existing snapshot. I wouldn't recommend taking a whole volume snapshot because of how easy it would be to fill up that volume with changes, then trying to recover from it could be a nightmare.
