Clammy
Aug 12, 2020Guide
Ready NAS 6 Series power issues
Hi,
I have two Ready Nas 6 series devices, the Pro 6000 and a 6310, both long out of warranty. I took them out of storage and put 4tb Drives in both of them but when I try to turn them on, they either spin up for a few seconds then die or won't turn on at all. I was trying to figure out why and I discovered that if I pull one or two drives out it'll turn on. It doesn't matter which one or two. One of them one of the drives that I have to pull out to get it working is one on a replaced drive sled (the originals were the ones with the paperclip button to release and I had to replace one with a newer slide button release type sled). It doesn't matter which hard drive is in that sled but if that sled is in, it doesn't power on or shuts off after a few seconds. I don't see how the sled makes any difference and when I look in the case, it does seem that the sled still slides the drive in tightly.
Both of these used to have slower 3tb drives in them. Is this a power issue? Are the drives drawing too much power? I originally thought it was a dead PSU and ordered another one but it turns out they will turn on, just not with all the drives in or that particular sled.
Any suggestions or help would be appreciated.
This is happening in both NAS? With different disks in different trays?
What happens if you try putting just the one tray in the NAS (leaving the others empty) and then power it up?
Are the symptoms different when you switch that drive to a different tray, and power it up again?
FWIW, this sounds like an issue with the replacement sled.
- ClammyGuide
Both NASes won't power on or will shut off after a few seconds with all the drives in. I have to remove 1 or 2 drives for them to turn on. It doesn't matter which drive, I've switched the drives on the sleds around and it didn't matter.
Only one of them has a replacement sled and if that sled was in, it would shut off or not turn on. But even with that one out, I'd have to remove 1 or 2 more drives to get it to turn on.
I have tried to take all drives out and just put 1 in, and it will turn on and stay on. I can't seem to find any sort of common problem. It's sometimes it won't turn on at all even with just 4 drives in, and I have to pop a drive out and put it back in then it'll turn on or unplug the power and try again.
This is really annoying since it's happening on TWO NASes. I'm just glad my primary right now is NOT a netgear.
That is a little more clear. So the replacement sled isn't working properly. Is this from a Netgear NAS? Does it have a part number you can share? Maybe also post a photo. There are a few trays out there, and it is possible you have one that wasn't designed for the Pro.
This would be the real problem then? This does sound like the power supplies might have failed - though odd that this would happen to both NAS. Are you certain these were working properly when they were stored?
It might be worth opening the chassis, and check the cabling. There are three molex connectors from the supply that go to the top of the NAS, and it is conceivable that one of them became loose or was damaged in storage. Though normally they are pretty tight.
Since you already have a PSU on order, you can of course confirm by installing the new one.
I get it is annoying, but the build quality of the Pro-6 is actually quite good. Still, components do fail, and you are talking about NAS that are getting pretty old (7-12 years).
Though I agree it is unusual that you'd have two NAS that both have this particular symptom - which is why I am wondering about their history. Were you the original purchaser? How and where were they stored?
