Lay901
Oct 31, 2018Aspirant
Ready nas duo, cant access samsung tv since upgrade to lastest firmware
Hi new to the forums and dont know much about nas to be honest but its worked fine for some years, have just carried out an update and can no longer see the nas from two different samsung tvs, i can ...
Lay901
Nov 01, 2018Aspirant
4.1.16
Nov 02, 2018Guru - Experienced User
Ok.
I'm guessing that the Samsung TVs are accessing the media files via ReadyDLNA - is that the case?
If so, you might try rescanning the media files via Frontview. There is a control in services for this.
- Lay901Nov 02, 2018Aspirant
Yes accessed as you described, have rescaned and still the same
