NAS-SAN-NAS
Sep 12, 2016Aspirant
Ready NAS not shutting down or rebooting - RN316
Hello folks in the community,
I cannot shut down my ReadyNAS gracefully.
Over the GUI it hangs on shutdown - the display is showing " Powering Off - Goodbye"
I also tried the hardware button method on the front of the RN - but again the display shows "Powering Off- Goodbye"
But the system doesn't shut down any further - it is stuck in that status.
What else can be done??
Running on OS 6.5.0 - but also had this issue under previous OS once or twice.
Update doesn't work over the GUI.
Is there another solution than pulling the AC Power Plug??
Starting the webinterface - I can still browse the shares but trying to reboot over the software I/O switch or the hardware button on the frontpanel won't work.
Any ideas ? Help greatly appreciated.
- JennCNETGEAR Employee Retired
Hello NAS-SAN-NAS,
When you try to update the firmware, what exactly happens? Also, when you change some settings, does it take effect?
Also, what are the apps installed and running? It is possible that there are some activities running in the background.
I also strongly recommend to (always) backup the files.
- mdgm-ntgrNETGEAR Employee Retired
Any update? Did you get my PM?
Any update?
