HIT-247
Jun 24, 2017Aspirant
Ready NAS RND 2000 How long install ? Flashing Blue Lights ben on for an hour ?
OK just carried out factory reset and used RAIDar to start installation. I am only using 2 x 1TB drives as a test exercise and it is taking a long time with flashing blue light mode ?
No response from RAIDar says RESCAN and finds nothing.
Should I be pateient and how long does it take ?
Or
Power down and start again ?
Thanks
- HopchenProdigy
Hi,
A Factory deafult shouldn't take more than a few minutes really. So, something is up.
You sure that your disks are OK? Could easily be faulty disks causing this behaviour.
